configure stacking node-address
configure stacking node-address node_address slot-number slot_number
Description
Configures a slot number on one or all nodes in the stack topology.
Syntax Description
node_address
Specifies the MAC address of a node in the stack. To view the MAC addresses for all nodes in a stack, enter the show stacking command.
slot_number
Specifies a number between 1 and 8 that is to be assigned as the slot number of the target node.
Default
The default slot-number for a node in stacking mode is 1.
Usage Guidelines
The configuration is stored on the affected node(s) immediately but does not take effect until the next reboot of the node(s). The configuration applies only when the node is running in stacking mode. To see the configured and active slot numbers of all nodes, use the show stacking configuration command.
If a node-address and a slot number are specified, then the node is configured with the specified slot number. There is no check for a duplicate slot number at this time; the number is simply assigned as requested.
To see the resulting slot number assignment, run the show stacking configuration command.
Failure to configure a node does not prevent configuration of the slot numbers on the other nodes, and does not affect the slot number assigned to each node.
When this command is executed successfully, the following message appears:
This command will take effect at the next reboot of the specified node(s).
To configure slot number 4 for the node with MAC address 00:04:96:26:6b:ed:
configure stacking node-address 00:04:96:26:6b:ed slot-number 4
This command was first available in ExtremeXOS 12.0.
Platform Availability
This command is available with all licenses and platforms that support the SummitStack feature. For information about which licenses and platforms support the SummitStack feature, see the Switch Engine v33.1.1 Licensing Guide document.
